I have a crank works 10 mm that i have run in my dasa for two seasons. I am freshening up the motor. Not sure if I should use this crank? It has some rust on it, but all the bearings are smooth and the rods are tight.
If the outside of the bearings are rusty u can bet the insides of the bearings were too at some point but it cleaned it off last time it was ran. All u have to do is ask yourself whats it gonna cost when the bearing comes apart and the rod punches a hole through your motor?? I would have it rebuilt. Best to be safe..
yea thats a little odd. Id just be sure when your done riding that its run good and hot to clear out any moisture in the bottom end. my entire motor went for a swim last year, and it didnt leav a mark, but i fired it up right after and rode it for around 2hrs that day post swamp.
