First off a little history since I am rather new to the forum. Started in stand-up jet ski's a little over a year ago and have decided to take the leap from my 95' SJ to spending all my extra money my own flat water ski. The hull I am working with is one most of you are pretty familiar with the WDK ROK hull I got from 'SKYWALKER'; which has been flipped, wrecked, sunk, and smashed a lot over the past few years but still manages to stay in one piece. Anyways the nose was cracked due to a well documented shallow water incident last year . So I decide that instead of fixing it I was going to just go all out and rocker the nose and try to shorten the ski up as well as take some weight off. I have no history of fiber glassing of doing much with molds, body work etc. So it has been interesting so far. The hull unfortunately has an sxr bottom deck so most of my super jet stuff works on it forcing me to buy a lot of new parts. My plans for the ski are the same as most novice riders I guess build a ski that can flat water flip with a 701 motor and not go broke in the process. A special thanks to bobob729 for his help, with this project.
Goodies I have for the ski so far
Bored 701 from my SJ
MSD TL and Light weight fly wheel (thanks McDog)
Solas 140 MAG pump with trim
Solas prop
R&D Intake grate
Dual 44 carbs
Parts I am planning on buying hopefully this year
Lmtd b-pipe, and manifold
ATP Water box
ATP steering system, and bars
ATP pole bracket
ATP lightweight aluminum pole
Aluminum gas tank
Mid shaft and drive shaft
Pump shoe
Ballistic Battery
and all the other little misc. parts I will end up needing.
Hope you will enjoy it all coming together.
Here are some before photos:
Solas prop
R&D Intake grate
Dual 44 carbs
ATP Water box
ATP pole bracket
Aluminum gas tank
Pump shoe
Ballistic Battery
