This morning I broke the point of attachment for the steering cable bracket inside the pole.
When I rang my local PWC Mechanic he suggested I use an epoxy resin type of glue to stick it back together. Apparently this is a common issue with SXI poles.
Later in the day I began to wonder about using CA (Cyanoacrylate/superglue) for this repair. I never cease to be amazed by the strength of this stuff but it rarely gets a mention here. I'm thinking of using two grades. Initially the thinner grade will be smeared on both surfaces to infiltrate the fibers and then a thicker grade on top of that for its longer cure time and gap filling properties. Then the two surfaces will be clamped together until cured. Positioning shouldn't be an issue.
I know that a two part epoxy is most often used for this type of repair but apart from common practice, is there any other compelling reason why I shouldn't use CA here?
