chriselmore_1
high on resin
- san jose ca
What do those numbers on top of the front exhaust port mean? Mine say 0 0 but have seen a bunch of other numbers on other cylinders
That's the sleeve port alignment with the cylinder casting and 00 is perfectly matched.
I hope its not port match, mine says 18 & 12
Supposedly it was how well the cylinder sleeves were aligned to the ports in the jug, but I think that was proved wrong.
Was there a thread about it? I've had two Wetjet cylinders marked "00" and both had PERFECT port matching. No "yamaha" 61X cylinder I've ever seen has been as close. Coincidence? No way!
I have a 0 - 0 61x cylinder here at my house. The mystery of the numbers continues....
the zeros probably had less to do with the perfect matching than the fact that they were wetjet motors. I've seen and heard that wetjet matching is way better than standard yamaha.
It would have to have something to do with tolerance wouldn't it? The only think that seems to change between mass produced parts is the pistons and rings. You never get a set the same and all decent engine builders will need the pistons before they bore to suit.
I'm sure Yamaha have some sort of setup that drops the sleeve in perfectly every time, so unless the castings on the sleeves and cylinders changes a lots, I really don't see why it would be port alignment that those numbers represent.
There's no piston mark though.... if the markings represent something about the bore sizes, then it seems fitting that the pistons would also have to be marked in a special way, or they'd get mixed up. Yamaha marked the 66E and 66V pistons, I believe (GP800 and GP1200R engines). Those cylinders don't have sleeves, the cylinder bores are nicasil coated aluminum. I forget if the 66E cylinders were marked.
The Yamaha stock port mismatch is horrible! Whatever they did, it was anything but consistent.
I do know someone that has contacts within Yamaha Japan, so I will ask the question...
Mine is stamped 00 and seems to line up pretty good. A little sleeve overhang on the top and bottom of the ex port. Is that where you look?
