I've been learning/working with a engine builder recently.
I was just wondering, cylinder reed motor makes more low end power than case reed engine. What if you took a 62t case and cut the intake off and welded a plate onto it. Then either had a custom cylinder with a cylinder reed intake set up made or just cut into a stock 61x/aftermarket cylinder and welded a intake on there. This could make more bottom end? Does any of this hold water? Like those newer billet cases could have gone this route, but then I guess it wouldent be a bolt on part. You would need a whole custom engine.
