Hi there just wondering if anyone can help me out with my new build.
Currently have a 701 in a EME Aerial 8 pro series with msd enhancer, tdr water box, b pipe, ada head, 145mm skat magnum pump, 9-17 impeller, stock 38mm mikunis. Just purchased a new Dasa 1100 10 mill from Thrust.
Was wondering if i can run the engine with new oem flywheel, no total loss (just msd enhancer), no power factor pipe (just b pipe), and 145mm magnum pump with 13-19 impeller, novitech 48mm, dasa billet intake manifold, v force 2, pump gas, pro k filters. Just don't want to spend another 2500 dollars on pipe and total loss just yet. Will it run well?
Here are some picsSkis as it is today 701 current build New Dasa 1100 10 mill from thrust on its way.
