Debner, you are a vendictive little boy, know wonder you & your mate got kicked off OZ Freeride.com for exactly this kind of stuff.
If your going to tell a story at least tell one that's true.
Firstly, yes i did build a motor for you with a 5mm crank & DASA top end kit supplied by you.
Porting specs were supplied to me by DASA as a measurement from the top of the cylinder to the top off the port.
After the motor was assembled, the squish was 2mm. I told you something was not right & contacted DASA & they said they must have sent the wrong domes by mistake as it should be close to 1mm squish - as you know!
When the new domes arrived the squish was 1.45mm from memory & told you something was still not right - as you know!
DASA thought they may have supplied a custom cylinder (which was made about 1mm taller than normal) to you by mistake.
Your motor was sent to DASA who confirmed that the custom cylinder was supplied to you by mistake which meant the porting specs would be totally out - as you know!
DASA made a new top end for you a assembled your motor.
You then got someone else to setup the ignition curve & tune it for you.
If your motor does not perform as it should, you need to discuss this with your tuner or DASA (as I'm sure DASA would be happy to help in whatever way they can).
There is not one part on that motor that wasn't put together correctly from my end, so to say that this is somehow my fault is an absolute fantasy.
We all know that you have the
s from the weekend because your ski did not run well & all the other skis that were with you that i tuned ran fine - & I'm sure that these riders would be happy to confirm this!
If you REALLY wanted your ski sorted & didn't want to just hop on the forums & behave like a tool, you would be contacting the people that built your engine or tuned it
