- Social Circle, GA
I just bought a dasa 864 SS second hand out of Arizona. It had too low of compression for my likings so I decided to just go ahead and put a fresh top end in it. The gentleman bought it from Kommander as an 850SS ported by Kyle at dasa. He advertised it as being an 850 original bore so I snagged it up. Went to order Pistons and decided to measure bore just for fun and they were 90mm, not 89mm so it's actually an 864. I also noticed that it had a shim in between two base gaskets which I also thought was strange. I'm sure it was to achieve the right squish but changing that from the base affects port timing. The original owner has been more than helpful with answering any questions I've had and is trying to locate the original emails between himself and kommander to see if there was a miscommunication or something.
So my friends, my question is does anyone know their squish height and port height measurements for an 850SS ported for freestyle? I'm feeling a little sketched out about it and want everything to be correct the first time.
