- Cleveland, Ohio
what’s your wager? @Zero ClientLift the PVs and test compression again. My bet is this is set up for pump gas @ about 185psi w 44cc domes.
Im not betting man.. Just trying to help you sell if it’s set up for pump gas.
I have seen some dasa’s that are high compression that will run on pump. They open up the squish band but lower the dome cc.
The older 850s had hand ported cases and rip.
GLWS
You were on FB saying the same thing. I’m just busting your balls dude.Hu? Well not sure what you mean by the social media comment - None at all. I'm trying to be helpful since I like these motors?
Every PV engine I've tested always changed compression readings up vs down; so I'd say it all depends on who set up this engine. Maybe those PVs are cut back further from the cylinder than mine? Maybe the engine's BD timing or someone lifted the boost port / is ported differently? GLWS. Great motor!
