mightymighty2stroke
I'd rather be on the lake
- LKN, NC
Decoding NGK Plugs / Spark Plugs 101
I was looking up some part numbers on NGK’s website and figured I would put them into a table and share. This post includes part numbers for solid tip plugs as well as other useful information on decoding NGK plug part numbers. Might help you decide what to use in a pinch or at the very least help you figure out the myriad of plugs hiding in your truck (wait, is that just me).
Note: NGK Part # helps you decipher what it is. If you go to a parts store, you’ll want to give them the regular part # I have listed. Some parts counter guys can’t cross reference so make it easier for them.
NGK Part # Example: BR8ES
First (Letter) - Thread Diameter. Most (all?) stand ups are "B" (14mm)
Second (Letter) - "R" or No "R". R means there is a 5k ohm resistor in the plug to suppress ignition noise. Plugs with a resistor are recommended in applications with on-board computer systems/GPS/depth finders etc. So this shouldn't really matter in your average stand-up whether or not it has a resistor. Factory superjet calls for one without a resistor.
Third (Number) - Heat Range. The higher it is the colder it is. For example 7 is stock for a 701cc superjet. 8 is a colder plug. 6 is a hotter plug. (Heat Range Explained).
Fourth (Letter) - Thread reach (how long the threaded part is, thus influencing how far down it reaches into the cylinder). Most common for us; H (1/2"), E (3/4")
Fifth (Letter) - Usually an "S" which stands for Standard 2.5mm center electrode
Plugs are available in either solid, removeable nut, or stud tips (tip = spark plug wire end). Solid as it implies is solid and won't unscrew. Removeable nut tips allow you to unscrew the nut on the tip. If you use these in your build you might find that the vibrations make the tips back off, causing loss of spark/poor performance. Stud tips are not used in our applications. If you are searching online you will want to add "solid" to the end of the part number to get a solid tip. E.g. instead of asking for "BR8ES" you want "BR8ES Solid". NGK's part number for a removeable nut tip BR8ES is 5422 and NGK's part number for a solid tip BR8ES is 3961 so there is a difference.
Examples of applying this information:
B7HS - 14mm Thread, no resistor, 7 heat range, 1/2" thread reach, standard 2.5mm center electrode.
BR7ES - 14mm Thread, resistor, 7 heat range, 3/4" thread reach, standard center electrode.
Note: Sometimes you will see a part number followed by -10 or -11. That means 1.0mm plug gap (.040”)/1.1mm (.044”) plug gap (respectively). I did not include these.
NGK Spark Plug Decoder Link
