Best bang for your buck would be going to the new Torrent 150mm. I love mine. Drops into a 144/148 shoe and will use the same nozzles/trim set up and gets you the closest to a 155 with out having to pull the shoe.
Torrent took my used 148 and made it into a 150. Their custom cuts were also applied to it.What did you do for impeller?
I have a 144 Solas Mag pump in a 14 Trendsetter Chan. Looking to see if going to a 148 setback mag pump would be a noticeable difference, bang for buck kind of thing. Trying to find some gains without going to a bigger motor. Right now I am running a 781bb motor.
The chan's had 155 tunnels. I would knock out the 144 shoe and install a 155 shoe ( if it doesn't already have a 155 shoe). No reason to go 148 when you can go 155.
I have a twangled Chan and a run an oem 155, there is plenty of room. Nothing lines up very well because it's twangled, but there's plenty of room for the big pump.
Exactly my point. I am talking about a 2014 Trendsetters Chan. Twangled made some changes weather they meant to or not??? Just like Twangled has 4 bolts for the ride plate in the chine rails verse 2 from Trendsetters. But with the quality of the Twangled ride plate, I would add more bolts to. LOL. Little salty here with them.
