08 SJ with a 701, mild porting, 180/180 compression, stock 38's and a B pipe with a flow control valve. When the valve opens it dumps a ton of water in the stinger, should I also run a restrictor in the line?
I'm probably over thinking this, but with duel cooling is it possible to move water too fast thru the engine and therefore not giving it time to absorb the heat?
