Does anybody know what reeds these are
I about ready to drop my bored and ported 61x into my sn sj. But can't stop thinking I should use the bottom of my 62T and run dual carbs. They are sitting on the shelf in perfect condition. (carbs need rebuilt) Should I and if i do, can i use these carbon reeds from the 61x in the 62T. Can you tell what reeds these are. It was built 3-4 years ago. 20170630_180034.jpg 20170629_131518.jpg
Roseand
The Weaponizer
Wisconsin
Can't use them in 62t setup. But they look like boyesen two stage reeds, not carbon tech because you can see the fiberglass section around the edge
If i used the 62T bottom under the 61K, Would i have to use the Flywheel and stator and ebox of the 760GP or can i stick with the 701 setup?
61x top and 62t bottom is ideal. Throw your 61x bottom in the bin along with the 760 electrics. Run the 701 electrics. 61x and 62t reeds are not interchangeable
