- Central Illinois
I modified a standard automotive steering wheel puller to remove my flywheel without pulling the tank. I just re-tapped the center hole to put a shorter/ larger diameter coarse threaded bolt in to push against the crankshaft. Use a flywheel holding tool and you can swap a bendix in 10 minutes or less.
