Done With The Turf!!! Pics!
HAMMER
SKI ADDICT
Thanks IHOP,
I'll post pic's when i'm done and i'll be sure to take my time.
Once The glue is dry and u put the mat down can u peel it back up with out tearin it if u need to re-position it. I've never seen this question asked.
Thanks
HAMMER
Superjet3
Waterlogged
Jersey Shore
HAMMER said:
Thanks IHOP,
Thanks
HAMMER
No, once you contact the mat to the hull it is stuck. If you try to peel it up it will rip. Are you using a precut kit or cutting yourself from sheets? If you are doing it yourself you should leave excess around all the edges and then trim once glued. Also prefit your pieces before applying glue. Good Luck and Def. Post pics.
HAMMER
SKI ADDICT
IHOP
Thanks for the tips .
Yeah I will be using a pre-cut kit from wamiltons
Ihope it don't look cockemied when i'm done.
I guess no beers till i'm finished turffing it.
Thanks Again
HAMMER (I'll post Pics no matter what the outcome is)
