Instant Nerf-morphing. So if you are about to land on your ski, or vise-versa, it instantly turns to Nerf material.
I have a ton experience with go-kart clutches. A dry clutch would never work dry clutches are not designed for long term abuse. When I race a dry clutch lasts only about 2 weekends. Wet clutches preform much better of over extend periods of time. A shifter kart clutch is basically the same thing as a motorcycle clutch in fact the 1st shifters were modified cr125 moto engines. There are also simple centrifugal clutches but they dont offer very good part throttle performance.
hell yes, you just gave me a GREAT idea.....
Funny thing is right after i turned on the BBQ, the dog filled up the grill with its own puppy made, stinky sauce !!How did that puppy come out? What sauce did you use?
Seems to me that an ajustable exit nozzle would be feasable. Seems that wouldn't be to difficult, except would the steering nozzle need to change diameter as well? You could use some overlapping plates that would ride down the taper of the nozze to either restrict or dilated the exit. Just a thought.
I'd like someone to make a pole spring made to work with the x-metal pole and a standard pole bolt on various brackets such as the WDK bracket with bolt spring support, blowsion, stock, etc...
I've custom bent a spring to work on my setup, but it doesn't work very well. I'd love to have something I can jut drop in.
Well Heck.. Lets just add a pole holder upper for those brackets too ! Now I know thats alot to ask for !
it does seem that I bend up a spring to get to fit everytime I change brackets..
i can't even count how many times I have been looking at someones ski, while they are holding the pole up, a girl walk by and BANG ! Right on the head !
seriously...no one cares though cause they all run stifflers anyways..okey:
Andrew... Wow, I never knew you ride stiffies !!!:AR15firing::AR15firing:
it drives me absolutely nuts holding up my pole to put on the hood. i have been considering switching out to a UMI pole just so I can have a brand new spring that will hold the pole up high enough to get the hood on.
