I went through this as well and did end up drilling. I found a hobbyist drill kit for about 7$. I just locked the drill bit into a bench vice and spun the jet down over the drill. It worked but this is a method that really should only be a very last resort. If you have the downtime then you should order the proper jets. Drilling them so I have read will reduce the inlet and outlet flow angles changing how the jet collects and directs the fuel, and certainly if the drill bit is not even on both flutes, it can leave gouge lines. I would assume that when Mikuni makes them they also have special reamers to give the best finish inside you could ask for. Drilling realistically should be only used for testing purposes, once you have determined the approximate size you need you should then put an order in for the new ones. For reference purposes though, I found these, and also a nifty little Mikuni pocket tuning guide...
