Drilling a second water fitting hole on the stock head?
Hey guys, I have the 89 650sx. I have a high compression head with two water fittings that gets 185psi and the factory kawasaki head with only one water fitting.
What i am trying to do is drill and tap a hole in the factory head to put another water fitting so i can still run duel cooling off the head. Does anyone have experience doing that?
The reason that I am ditching my high compression head is because I blow head gaskets all of the time with the high compression. I used a Kawasaki OEM gasket and sooner or later It leaks witch ends my riding for the day.
Get the head and cylinder decked. Thats why it eventually leaks. Its not the compresion doing it , its uneven surfaces. Ive had the same problem before. But yes , you can tap a stock head just like the aftermarket head.
