Driveshaft Spline
sneds, your midshaft is in sad shape. However, since it's over $250 to replace midshaft and driveshaft, you might consider using the old until they strip (that will happen suddenly and without warning- so don't get too far from shore). It is absolutely mandatory that you replace the two "o" rings in the midshaft, otherwise the grease will (!) wash out in minutes and the shaft will strip soon thereafter. I buy those o rings in bulk (Buna N) and could send you a couple.
@augustaf I'll pm you about the o-rings. Thanks for the help everyone. New midshaft and driveshaft being ordered from JM.
Sent from my C6906 using Tapatalk
