SX/SXi/SXi Pro Dry pipe in a Sxi pro???
Tuscaloosa, AL
you are going to have to reroute the entire exhaust hoses to connect to the waterbox which is behind the pipe. Dont know if that guy had a waterbox mounted up front or not. He may have heated his tank to get clearance. Wait, I told you Speedwerx 800 Pipe, this was for the 750 if I am not mistaken..... you man can shift the tank to the side some and install a wedge to keep tank over.
Ok I’ll check it out. He told me it was a team Kawasaki pipe or something lol.
Tuscaloosa, AL
EWCI is a water controller that injects water into the exhaust stream early on to make the pipe think it is "longer" which will give you more bottom end then it turns off to let the mid to top take over. It is just a tuning tool. It helps give dry pipes more bottom end pull.
