Nice any input on the nynja chamber ?
Lpw 735 61x 61x original 44 mikuni carb. 9/15 hooker stock pump and cone. Type 4 dry pipe with fcv and jet in stinger.
Your not bugging at all def appreciate all the input .One more thing I will add and I leave you alone. I was told i would have nothing but trouble with this pipe there junk won't stay together blows couplers etc... This has been flipped, rolled numerous times. Still on first coupler and o ring. Don't believe everything you hear and read on line. If I had I would have never given this a shot and would be less then thrilled with my setup.
With my compression and the dry pipe I run leaded 110 gas and castor 927 to be safe.
Can I run the c4 with my factory pipe manifold ?C4's are supposed to be a little better then the Factory blaster Mod chambers. Although if you have the money TnT is made a new pipe to compete with the rrp
This pipe blew many a coupler and o - ring until Chris figured out all the tricks to getting it set up correctly. Then still blew some.One more thing I will add and I leave you alone. I was told i would have nothing but trouble with this pipe there junk won't stay together blows couplers etc... This has been flipped, rolled numerous times. Still on first coupler and o ring. Don't believe everything you hear and read on line. If I had I would have never given this a shot and would be less then thrilled with my setup.
I'm going to go out on a limb here and say that an sxr dry pipe will not fit in your emeWhat's a better set up for a freestyle freeride ski ? Dry or wet ?
Are dry pipes louder then a wet pipe ?
