My type 4 ran parallel cooling (separate).
Will you be running EWIC ?
They’re is a micro touch controller in the FS section, they are good and start ON is 1500 rpm... lower than msd’s 3000 rpm
Just T EWIC set up in to line to manifold lower fitting, then rout it to the spray bar in manifold and it spraying into pipe and away from the engine.
Your first drawing is good...my manifold only had one large barb fitting on the bottom.. I’d ditch that pisser off the stinger.... also if you do run a FC valve, adjust it for max flow to start with... mine ran bettered with more water to stinger...
Here is mine, note; I drew the 2 lines to stinger fittings backwards
Flush kit ? I ran 2, one for pipe and one for engine... now I just back flush via the pissers.
Blowsion has a back flush kit you can view or make your own too.... round hole 45 deg pissers, 90 deg are harder to get flush pipe in the pisser hole.... if your running just fresh water then no need....
