Dual 38 speedplate in stock at JM
Looking for a speedplate or the stock mounting plates for dual 38s on a 701 62t manifold.
Dual 38 hsi speedplate also in stock at JetManiacH.S.I. Billet 62T / 64X Carb Manifold Plate
HSI billet carb manifold plate for Yamaha OEM intake manifolds. Offered for 62T (38mm) and 64X (46mm bore). The 64X one-piece plate: Allows you to adapt dual SBN 44mm up to 48mm carbs onto the OEM 64X intake mani. Bore size of 46mm. The answer to putting larger performance carbs on your OEM...highspeedind.com
