WFO Speedracer
- Alabama
You want to explain this one Matt lol
Can I open this thread again.
I am looking how to plum your lines with 2 high flow fuel pumps. My tank has 2 outlets.
I know the supply nipple will receive direct from the tank.
The one goes to the pulse nipple on the intake mani.
Then there are 2 outlets left on each pump. Can i just Y-connect them and
go to carb?
Thanx
You would be fine to “Y” the two outbound feeds together into a single line to feed each carb, just get a fuel pressure gauge to verify your numbers are in spec and adjust jet size in your inline return fitting to get the correct pressure.I am looking how to plum your lines with 2 high flow fuel pumps. My tank has 2 outlets.
go to carb?
Thanx
What carbs do you have?Thanx guys for the info.
I have a 60 return jet in at the momwnt. Its a 1200cc freestyle ski. What would be the ideal fuel pressure?
For those I’m not sure but I generally aim for between 1-2psi at idle (under load) and 4-5 WOT. Those are the specs Novi recommends and i have been using those pressures on all my carbs, Novi or not. Wouldn’t hurt to ask the manufacture though.50mm SE carbs
