Vumad
Super Hero, with a cape!
- St. Pete, FL
I am talking large amounts of dust. Sanding a mostly flat surface to prep for paint with a vacuum disc is manageable. Grinding out large areas of damage and prepping them for new glass generates a bunch of dust. High speed grinders, discs on die grinders and other tools for these not flat surfaces needing a lot of removal/prep generate huge amounts of dust that are hard to collect.
Examples...
Trimming/sanding a part pulled from a mold
Fiberglass when cutting a bunch of fresh glass for a layup
Grinding down a damaged area of a hull
Removing larger amount of improper repair / bad bondo.
Sanding and shaping a plug
How are you guys managing dust? Right now I work on my carport. I use a 3m chemical 1/2 face respirator and vacuum what I can. Inevitably dust ends up on everything around. I am looking for a professional quality solution at a hobby price using hobby tools, there is no income generated from my projects.
I hang tarps when I need to spray gelcoat or paint. I'm thinking about something similar for sanding. Maybe a 2-stage fan. A box fan pushing air into a funnel box that is connected to a shop vac that will filter the air. So far that is the best I have come up with.
I'm also thinking of switching from the 1/2 face 3m respirator to a full face 3m respirator or a PAPR, but I wont be able to get anything until after COVID.
Examples...
