Dvx resto
Sanoman
AbouttoKrash
NE Tenn
If the corners are ground down from wear and tear,you can use a mix of thickened epoxy and carbon shredded up.And if you have enough room,maybe put some 12oz woven carbon over the area.Sanding it down to blend in with the rest of the surrounding area. Tough areas to keep from happening again.
Put some pics up when you get the hull
