Gear heads,
i'm planning on checking the dynamic timing with an inductive timing light. I've set my static timing at 28 degrees (-5 = 23 actual). With the ski idleing should the timing light show me timing of 28 or 23? Since the marks i made on the cases are only 5 degree increments do i just eyeball the timing during the strobe flash, or should i just retape my degree wheel i printed off the computer and tape it back on the flywheel. Is there a chance the static and dynamic timing will be different? What if they are diff?
