E-Box Clicking
Hi dudes need your advice , starting my ski after the Winter layover and it started fine 1st. time , ran it for 20 seconds and turned it off. Pressed the button to restart and nothing only a clicking sound from the E-Box. What did i break now...! Thanks in advance...
DAG
Charlotte, NC
Likely your noid/relay. Try jumping the 2 post with a screwdriver and see if your starter spins. Of it does your noid is bad
Before you take ebox apart eliminate that it's a bad ground which can cause your issue. Take jumper cables and run negative leads from motor head bolt to negative battery and then try starting it. You can further check it by adding leads from ebox bolt to motor in addition to previous. Good luck, report back.
GA
Give it time. Same thing happened to mine, verbatim actually. If it happens again it's most likely your solenoid. Before I bought the ski it happened to the previous owner but didn't ever go for good. After I got it it went for good so I replaced it and no problems since
Dudes , battery fully charged , new starter motor relay fitted , still clicking. Extra earths added (1) from engine to earth on battery , and (2) e-box bolt to engine , still clicking. Motor relay , jumped the 2 posts with screwdriver , still clicking..... :confused: What should i check next... ? Thanks...
DAG
Charlotte, NC
What do you mean by the noid clicked when you jumped the post? By jumping the post you are bypassing the "click".
Mystery solved , went to remove the starter motor to have it checked , came apart as i removed it.... the two long skinny bolts that hold it together were missing. Found them under the bilge pumps...! A big fat thanks dudes , for all your advice and patience.... 10/10 :)
