FX-1 E- box upside down?
Dirtybird
Ex*ta*ski
St. Clair, MI
Installed E-box and all the wiring is on the bottom and on opposite sides?
Took box apart and that is how it is all routed.
Had the box all redone by jss.
Guess I could drill New holes for the box.
Anybody else have this problem or is this normal for fx.
hornedogg79
dodgin' bass boats
I used my fx1 as a donor ski when I built my f1pro. THen later used a superjet's components to rebuild my fx1. I ended up installing the ebox upside down to make it work. It's been like that for a few seasons now.
Jp79
Building Brawlers
Harveys Lake,Pa
I run mine upside down, keeps things clean looking vs a big pile of wire all over the place. And you can get into the access port easier
Stockton
My Rm nose Sj has a factory dry pipe so I run the box upside down so my plug wires are not on the exaust pipe, been that way for 7 years no problems, almost seems better with no battery wires out the top for water to protrude thru, battery cables are plenty long too
Dirtybird
Ex*ta*ski
St. Clair, MI
Thanks for all the help guys.
Going to ride the sn today so work stops on this.
Another question..... the tube coming from the pump through the bulk head,why so big?
Big enough for bilge hose almost.?
