E-T 1107 Dyno results
Th3g3rm4n4t0r
Brawlin' n Flippin'
I know there aren't many videos of these motors in action. I've posted some, but I'm a mediocre rider at best. For anyone skeptical of the power that these motors make, go ahead and check out 31saif31 on Instagram. I think that will shatter any doubts that people may have. He bought one of the first ET motors and he posted a pic of 2 more that he bought shortly afterwards, so obviously he was impressed with them.
https://www.instagram.com/p/2DiruGpThb/?taken-by=31saif31
https://www.instagram.com/p/6KrtJypTkT/?taken-by=31saif31
https://www.instagram.com/p/1k5PfNJTuz/?taken-by=31saif31
Yeah i shiit myself when u gave me that dudes IG name.. Wicked!
ON
Hers is some Crankshaft testing data .
ADR Crank full circle makes 15 hp 20 flb torque less between 5200 to 6300 rpm but make 4 hp more on top from 6600 to 7000.
than the PHP Crank.
So why does the PHP make more mid range? It is lighter and is a Pork chop style.
-The test was with same carbs, cases , Cyl ,domes ign only thing was was changed was going to a PHP crank.
-It is all about the crankcase volume. Increased volume = less pressure = less blown out the EX at low RPM
-If your looking for more top end then go with the ARD.
-If your looking for that mid range package then go with the PHP. Little more cost.
Now most won"t see all the gains unless you run a tall prop 13/19 is what i used in the water testing and it was a huge dif.
With a Low pitch like a 9/17 that I just installed couldn't compare cause first ride at Daytona will know more in a couple months.
It's all about the prop setup for you app.
Quinc
Buy a Superjet
California
Got an 1107 on order for @Emily
mike b
California
Damn. I know what my 1105 does. That chick must have dome brass balls somewhere because that motor can be scaring sometimes hahaha. Can't wait for pics and videos when she starts riding. Congrats Emily
lol some people on here would try to make you think so,a few others use them that have access and money to do it,youll just never see the results
