ebox screws
brentR
way fast whitey
Toronto
what thread are those lame phillips head screws that join the ebox together. mine are all mangled. what can i use to replace?
OCD Solutions
Rentz, GA
Gonna bump this up and hopefully get an answer to this that we can add to the Mcmaster List.
After digging up the number somewhere on here before, I purchased 100 of the 92470A315's from Mcmaster but they just seem way too big unless you already some that are stripped out. I wish to find something closer to OEM.
Pan Head Phillips Screw for Sheet Metal, 18-8 Stainless Steel, Number 14 Size, 1" Length
http://www.mcmaster.com/#92470A315
The references from the Mcmaster Carr Master list thread are;
Oversize Screw for Ebox Cover, stainless, 5mm shoulder dia, M4 thread: 90278A321
http://www.mcmaster.com/#catalog/121/3072/=yvr41r
I'll have to look up my receipt from Fastenal for what size I used, but I replaced those screws with square drive button head screws. You can torque them down and never worry about stripping the head.
That's a Robertson head, designed in Canada, so much better than Philips!! :p
I'll see if I can find the size, but I am positive it wasn't an exact fit to the OEM screws. They are slightly oversized, but they still fit and grab much better. Huge improvement over Philips. Thank you Canada.
OCD Solutions
Rentz, GA
The Plastite series of screws seem to be the most similar to OEM but I will have to check with a set of calipers to see if I can match up the right size. They come in Phillips or Torx.
I just went through this recently. Never bothered to look for replacements yet but the OEM screws are a special made for plastic screw. If I remember correctly, the closest I could find was a numbered size, not fractional....ei, #10, not 1/4. But as mentioned the sheet metal screws have quite a bit more diameter or well too small depending on the size you compare it to. I have seen these plastic screws in tons of other plastics before, you can always tell too because they have that double spiral where the one is small and close to the core, and the other is larger and flared out. I think the plastic screws are also used on the fiberglass such as the filler neck flange and where the nose cover on the SJ screws onto the handlepole location just above the engine cover hood hooks. I will have to find something eventually, when I do I will post up the results.
Found it... do a search for Stainless Thread Forming Screws For Plastic. Here is the first search result I turned up...with a little additional searching within the page. But I believe this is what you want to look into or look for elsewhere...
http://www.trfastenings.com/pages/Plas+Tech+30+Screws
Fastenal calls them Steel Plastic Thread Rolling Screws...
https://www.fastenal.com/products/details/0142872;jsessionid=6FA674BDD57EB6C89A98E99B96A7CC9C.fcomjvm04?r=~|categoryl1:"600000 Fasteners"|~ ~|categoryl2:"600051 Screws"|~ ~|categoryl3:"600068 Thread Rolling Screws"|~
Another resource calls them High Low Style Thread Forming Screws, you can buy them by the 10,000 count if you wish :D
http://www.fastenersuperstore.com/products/352831/thread-forming-screws?pid=17418
Amazon search results:
http://www.amazon.com/s/ref=nb_sb_noss?url=node=16410611&field-keywords=High+Low+Thread+Forming+Screws&rh=n:16410611,k:High+Low+Thread+Forming+Screws
Staytite Fasteners...
http://www.staytite.com/products/thread-forming-screws-for-plastic
For our friends in the UK...
http://www.harrisonsilverdale.com/products/screws-for-plastic.html
You see what you have started OCD lol...I need to stop now before the clock says 5am...again lol. Hope this helps fellars, it was good for me too as now I know what they call them and how widely available they are.
I bough mine from local hardware store with 10mm heads. I only had to grind off the tip of the screws and it turned pretty close to OEM but with reliable and long lasting 10mm head. You gotta be careful tho as they tend to strip through the plastic if overthightened..
