EBOX'S ATP or ColdFusion?
As for ATP vs the cold fusion. It's a no brainier. Cold fusion all the way. The biggest thing is you can't run msd in an ATP without drilling a hole in it and making it no longer water proof.
I have a cold fusion Ebox and its good too. Solid/clean design and holds up to abuse.. Pricey but worth the investment. On the flip side a well set up OEM Ebox will perform just the same. The piece of mind of being able to see inside is the key.
I cant find the cold fusion middle section that uses the oem back plate. Does anyone know where I can find one?
