- New York
But snowmobiles don’t have water and I think that’s going to be more of the issueSeem to work okay in snowmobiles.
Run pfp or another dry pipe?But snowmobiles don’t have water and I think that’s going to be more of the issue
Maybe? Saw a video of it running on Facebook and you don’t brap it. The rider was just holding the throttle at a constant rpm. Don’t know if that is how it has to be ridden but looked like it lost that on/off brapping.Run pfp or another dry pipe?
I believe most sleds run EGT sensors to infer lambda (air fuel ratio) rather than an actual UEGO it looks to use in this kit. Love the idea but a UEGO likely wont live with oil, might be best to re-release the kit with an EGT.Seem to work okay in snowmobiles.
In my (rather limited) testing on marine 4 strokes it is hard to keep an o2 sensor alive unless you run WOT and then shut it down and pull the sensor. Even letting it sit and restarting causes loads of water vapor to form in the exhaust which kills the sensor when the heater kicks back on.I believe most sleds run EGT sensors to infer lambda (air fuel ratio) rather than an actual UEGO it looks to use in this kit. Love the idea but a UEGO likely wont live with oil, might be best to re-release the kit with an EGT.
Mount some lectrons on your ski.I don't really want efi, I just want carbs that are convenient to adjust. Can you imagine having a set of carbs that somehow mounted the jets on top, like as easy to get at as a spark plug, and put the screws with a nice big knob with graduations so you can just grab it and turn it 1/8 turn without cramming your hand into a tight place with sharp edges? Even better a flex connector and a knob that you can reach while riding, don't even stop.
Hit up lectron and see if they will help you set some up for your ski.Someone needs to make some Lectron Carbs for the skis!.
I've personally used them on multiple different dirt bikes and they were always awesome. They all always felt super well jetted and never running lean.
Its a metering rod style carb or something like that.
I wish! Im sure it would be expensive to have them make the first set for me. Plus my ski is stock with some bolt-on's and a pipe. So nothing really special on my SJ. Plus its apart right now for some work im doing to it and have been busy.Hit up lectron and see if they will help you set some up for your ski.
