- Annapolis, Maryland
im about to torch it.
push start nothing happened. i used a jumper from the battery to the brown wire on the ebox side. it cranks fine. so i figured i had a bad start/stop switch. i yanked the one off the blaster and tried it. nothing. no spark no crank no click. checked out the wiring harnesses and they look fine with no corrosion or messed up connections.
where should i go next with this?
