naticen
- wilmington, nc
Got 62t electronics and it breaks up like crazy on the top end. Stock CDI so I swapped in an enhancer that was good 3 years ago and I pinched the brown wire on the solenoid under a ground screw like an idiot. After trying for a while and finally see what i did, I put in another solenoid without pinching the wire.
Then the enhancer only sparks when I let off the start button. Figured I fried it or maybe was bad, buy a brand new one and throw it an and same thing. Swap out the old cdi and it starts up instantly but still breaks up on the top end.
So then I test my stator coils by cranking it and checking voltages. The charging coil is fine, but the pulser is also putting out 30 volts instead of the 4 to 5.
Is it possible all the cdi's are fine and I just need a stator or? Did i cause this problem by pinching the wire or was that always it?
