EME 1000 build
Nice. Good to see you finally found the perfect setup for you.
Post more pics and videos as you get them, please.
c12 is about $8 gallon. I'm gonna leave it alone, dont want to risk damage, Some better resolution pics. I plan on returfing and re vinyl this winter after season ends. Im also going to prop up 1 degree and make a composite ride plate, right now Im running a cut down stocker. And I'd like to get a 3 gallon Jazz in there.
Roo
it's all good
Looks great - what are you coating everything in the engine bay with?
Everything seems to have a glossy shine to it.. WD40...something else?
-Andrew
Roo
it's all good
Wd-40, help keep our water from staining everything
I am going to start doing this. My lake water leaves water spots. Not terrible, but would be nice to keep everything looking :notworthy:
No problems of it eating away at case paint, gaskets, wires, etc?
Sorry for the million questions - someones gotta ask 'em.
I haven't yet, but I'm sure it's coming. Eric uses a pipe on the carb side that has a upward bend so it's about as high as the carbs. I'm going to do the same. I have a silencer built in the hull and I know that helps a bit. I'm real careful to not have my weight on the ski while it's floating in the water and it goes on a stand immediately after riding
It won't hurt anything, I spray it on everything. I'm looking forward to ur installation of the 1000cc xscream into your fs1.
Whats the difference between C12 fuel and 110 octane leaded fuel????
