Eme q8 build
Hull weight is claimed to be 68-70lbs.
SPECS
q8 hull
85mm (flattops) billit pv DASA cylinder
ADA head 200psi
billit crankworks 8mm crank
dual full spec 48 carbs
Boysen rad valves
Msd tl ign
BUN dry pipe...(on the way
custom 2lbs carbon waterbox build by me
Bun billit adj pole...(on the way
SXR 145 billit skat mag setback 12v
Scat trim w/bored reduction 85mm
billit couplers kawi style
Will post pics soon as i get them. I will be driving down
to his shop to pick the hull up when its ready. He is only
6 1/2 hrs from me, so road trip will be in session. The
hull comes complete with foot holds, ride plate, drains, hood. The pole bracket is built into the hull with opptional
mounting. Paul from LPW did all the motor work for me as far as case porting, billit plate install on the bottom of the cases and clearancing as well as cylinder porting. He has been a big help to this project and has become a good friend over the past year and a half.
Pics added of the BUN dry pipe, ur able to run a waterbox.
I was going to go with the eme style but alot of my practice time will be on my lake till sun down...so this was a must. The pipe was 1550.00 not include the ship from Japan. The billit pole was 1500.00 and the weight is
6 1/2 lbs.
YUPP... Iv saved every penny for this...Im buy far rich and had to take in many side jobs to make this possible. I have
2 little girls. One is 2 and the other is 8 months...the oldlady is so fusterated with me, i told her when the ski is done then i will start
a savings, lol.
This yr i didnt want a repeat of the previous year. I was
to busy making molds and parts that the build never got finished in time. As seen in the 24-7 7mm backflip build. I plan
to accomplish what i set out to do last yr.
Weight is said to be in the realm of 68lbs for the hull built
with foot holds. I couldnt tell u lengh at the moment but will find out and post it.
