Custom/Hybrid Eme q8 pipe options
wi
Hey guys, I have an eme q8 with a yami power plant and a b pipe. What (dry) pipes fit in these hulls? Running a kart tank as well. Thanks
motozachl
uPsiDeDoWn
JAX
A limited bpipe wouldn't fit even with the smaller ATP waterbox for me. Had to use a mod pipe............if this even helps you. I've read several times that a power factor does infact fit just fine though too.
I had no problem fitting a limited b pipe chamber in my w q8. Worth noting I was running Tem's carbon superfreak water box. I started mocking up a PFP last week and it will fit, it's pretty snug but it will fit.
wi
Thanks guys. I have an fx1 chamber right now so it should fit. Curious if a speedwerx freestyle pipe would fit. A power factor would be too much for my ski at the moment, also not really in the budget.
