'07 800SXR, hard to start after it has been in use for some time. Need to hold the start button in and give gas to make it start. It would never start if you didn't give it throttle at the same time.
When it is cold with the choke on, I also need to give it gas to make it start.
-Still under waranty but the dealer doesn't try very hard to find the problem.
To me the carbs just don't give it enough gas on a cold or hot start. Maybe both carbs aren't adjusted together properly?
[thks for the input with water in eng compartment]
