- Asheville, NC
Just curious what most of you are using on the bolts during engine assembly. Grease? Threadlocker? Anti-Seize? Nothing?
Which bolts? Threadlocker on intake and exhaust manifolds, Flywheel cover. AnitSeize on headpipe bolts and motor mount bolts.
I used that everywhere the manual specd it, but when I took it apart it’s really difficult to clean and very messy. I can say it will definitely keep the threads clean and dry though!I use thread sealant
Don't use threadlock on the head bolts because you should be retorquing them after the first heat cycle.
I don't think yamaha used anything on the head bolts at the factory?
Kinda strange but they spec Loctite 572 on the case bolts, motor plates, and cylinder head. It’s thread sealant like you would use for galvanized pipe and such. It works really well but it’s a pain to clean off. Somewhere between silicone and anti-sieze, it never fully cures.
572 is red Hi-Temp Hi-Strength thread locker.
I use 567 Hi-Temp thread sealant,, it cleans up pretty easily with a wire wheel.
oops you're right!No, 572 is a thread sealant not a high strength thread lock.
Medium strength thread sealant for coarse threads on metal pipes and fittings. Slow curing to allow adjustment after sealant application.
LOCTITE® 572 is a white to off-white, medium strength, methacrylate-based thread sealant for metal pipes and fittings. Suitable for coarse threads, it offers a breakaway torque of 7 Nm. Slow curing attributes allow users to adjust the alignment of fittings. Suitable for thread sizes up to M80, it is thixotropic to reduce migration after application.
- Slow curing to allow fittings adjustment
- Designed for metal pipes and fittings
- Suitable for coarse threads
- Medium strength
Just did this on my TS650. Headpipe bolts are not SS, so a good coating on all over is what I do.Which bolts? Threadlocker on intake and exhaust manifolds, Flywheel cover. AnitSeize on headpipe bolts and motor mount bolts.
Thank you. Red-nTacky is what l use.Just need to check them more often.That came from Chucky years agoI put marine grease on everything.
Actually,it’s quite interesting to see what others use.May learn from getting other ideas and opinions.Sometimes I just like to stir the pot![]()
