Hello everyone, I figured I would post this in the general forum because my engine issues could be common to most ski engines. A little background, I have been reviving a 1988 650sx from the dead. Engine mods include: shaved head, 38mm keihin carb and mathing manifold, K&N filter, aftermarket pipe and waterbox. After tearing the motor apart to clean and inspect I found the water in the engine cases. After flushing the bottom end, I found the rod bearing and crank looked really good. The Reed cages were corroded and needed to be replaced. I found some on flee bay and reassembled the engine. When cranking the engine I found I had a very weak spark. Again I found a cdi unit on ebay and now the spark is good. So here is my problem: The engine will only run at high RPM with tons of choke and for about 20 seconds. The smoke coming from the exhaust is crazy. I did put a bunch of 2 cycle oil in the bottom end after the flush but tried to drain as much as possible. I thought maybe the oil in the bottom end would be causing this, but I have ran it enough to burn that off I would think. I also noticed that when the engine starts to die an orange flame burns burns in the intake. Do you think this is a main seal problem, or a reed problem? I have gone through the carb and it is emaculate. Jetting is 155 main and stock pilot. Engine ran perfect with these settings 10 years ago when I put it up. Engine will not start unless choked and wont even come close to idle.
Any ideas on what could be my problem? Thanks for reading.
-Tmoney12
-Tmoney12
