Has anyone else experienced their engine firing in reverse with and epic?
It seems to happen to me a few times when the engine winds down to lower rpm every now and then it will reverse the engine. It would seem like too much timing but the engine is at the rpm where the timing is down around 16* when it does it. Does anyone have suggestions on what to test to see where the problem is?It sheared the flywheel keyway on me this weekend and it bitched up the tbm flywheel a little not sure if it's useable still or not
