- Michigan
Hey guys, bought a new ski the other day but I'm having this weird issue where it doesn't want to move when given gas. It'll fire right up and Idle perfectly fine in water and moves while idling.. until applying a small amount of throttle when trying to idle out which then forward propulsion stops, losing all thrust. Literally struggles to move forward at all with any throttle but the engine sounds like it's really going (not bogging out). Kinda feels like the driveshaft is slipping? It's a 92 SN 701, impros hooker, Riva intake scoop grate, ported bottom/top end, recently rebuilt and all new gaskets. When I went to check it out it wouldn't start and the seller was fiddling around with the starter and bendix and apparently there were a few missing or loose bolts on the starter. Not sure if that is relevant but other than that and a missing flame arrestor, everything else looks solid. Still consider myself a wrench noob but learning as I go so bear with me Any help would be most appreciated or pointers on where to start first to rule out any obvious culprits before having to pull the engine lol I can post pics or videos on request.
Thanks a lot!
Thanks a lot!
