chriselmore_1
high on resin
- san jose ca
it will work great!
Have not tried an epic with a 61X stator , other than a timing change, is the spark as strong as with a 62T? Any other differences noted? I trust the modding of the 62T manifold entailed blocking the crossover?
62t as a 5mm stroker with a 3mm base plate, Damn this thing must have had some transfer port timing in it.
Good on your for running the engines up on the dyno and putting it up here.
Aaron.. Bro get that thing operational,I watched 3 of the top fl guys in flatwater all argue whos 1000 hit the hardest,all 3 had different opinions on what was making the most power after riding all 3,IMHO its almost impossible to know once you get past a certain level.It would be similar to tuning 3 1000 hp cars with no dyno or time slip #s to work with or Trying to drive in a 900 hp and 1000 hp car one at a time in a parking lot and tell what made more power.......
dyno tuning would be cool to a certain point,but the big advantage is testing different types of parts on the same or similar tune based on the part being changed to find out what is truly the better choice
Chris,let me know when you have it confirmed the epic and jetinetics fw are tested in the water and working 100 %,that is also very interesting for a analog to dig converter cdi to pull off
I can tell you with 100% certainty that the epic works flawlessly with a 61x stator and jetnetics flywheel
Db
