Reliable wouldnt be the first word I would use. Mine you randomly kill the ski when ridding. Also if your electronics aren't perfect good luck using itThe EPIC is a very good product due to few aspects:
- plug in and feel the difference, timing advance is your friend - especially with pipe and compression combo
- fit in ebox so pretty safe and the latest ones have new updated software in them and are very reliable
- you can adjust (upload/modify ignition curves) them via cable to your PC and you have the possibility to switch in between 2 different curves with a turno of a button (additional item)
ATP will also assist you anytime if there is a need. Go for it!
^interesting, I thought msd was the better unit... but basically epic has problems running with older electronics..say 1997? haha
