I recently installed a used EPIC CDI on my Blaster and I have zero spark. I installed a used OEM tested 62T stator and lightened flywheel from Jetmaniac and new oem coil. I'm pretty sure I hooked everything up right. The only wires not connected are the black and pink wire to be used for a switch which I'm not using and a couple extra ground wires for the temp sensor. I am able to connect to the CDI with my computer and load and save curves to the ignition. Any thoughts? Do you think the CDI is toast?
