et 1107 krash
US
Got rid of the crapy pump tunnel scupper and added out the back scupper the new h2o
US
US
Sorry no but i used a 2 inch pvc , the stock pump tunnel is fiberglass and goes all the way to end of stock scupper ,you only need like 8 inch of pvc drill the hole then i epoxy it in you have to dry fitt the pvc then mark it and cut it to the contour of the hull inside and out i left about a 1/2 inch sticking in on inside so i could epoxy it in you will have to remove atock one to do the work to epoxy pvc
Damn what a work but it has to go in the one in the pump is sh#t
Can u make a photo of true the firewall for me ?
Verstuurd vanaf mijn SM-G920F met Tapatalk
US
That will not work on stock scupper the krash hole is 3 inch you will have to do what i did to make that one work add 2 onch pvc i bought same.one you have so i know from experiance to use that ir will.have to come out the rear
Yes i was planning to make it to a rear scupper the hole in pump area is the wrong place for a scupper...but thinking of making a little water ramp and no tube..so i dont have to run a little scupper under the ti scupper
US
Could not get a pic of tunnel. But their is foam between the end of scupper hole and back of ski about 6 inches deep
