- North East Pa
Can confirm Prickter's jetting recommendations work very well.Seriously, only running 93. I am running this set up.
180psi
Dual 46 on php mani and v2s
2.3 n&s
120p
110m
Pop off 18
3/4 out on low
1-1/4 out on high
PhP laydown / ran dry
This ski dialed in on the fat side. Also running Dominator at 40:1.
On a side note, ran a compression test yesterday at 180/180, and dropped a scope in the cylinder, pistons are still clean as the ski is running on the fat side, and cylinder walls are still perfect. Motor has 25 hours since it went to 94.5 pistons last year, and will be for sale in the next few weeks after my new motor is built. It will come with extra PV blades, springs, bellows, retainers, and extra domes.
We are running a similar setup.
We are slightly richer, but ambient air temps are cold right now (between 40-55F).
160 psi
Dual 46s on a Riva Mani with 760 reed cages
2.3 N&S gold springs pop off is 22psi
125 pilot
115 main
1-1/4 out on low
1 out on high
PFP V3 dry
40:1 Premix
155 OEM Pump, 9-15 skat
