ET piston's 94 , 94.62 , 95 mm
improved et pistons. More points of lubrication , and strong piston skirts. There were designed and modified to be better then original working with the engineers at wiseco pistion.
These were designed off a ET1200 piston with 16mm crank, if using on 1107 or 967 the skirt will have to be cut , i can take care of this prior to shipping as well.
94mm stock , 94.62 and 95 mm available. if going over bore you can also send your cylinder in to me and have them bored as well. I do not carry or make any other products for et motor
$240 per piston
$20 per pin bearing
$15 flat rate shipping in US . will ship world wide
Just got mine. Looks like a good replacement to me!
Sent from my Pixel 3 XL using Tapatalk
NC
I’ve been running a set of these pistons this season (about 25 gallons so far) and no issues at all. Everything worked out great and nice to have availability for ET pistons.
