I am getting frustrated with my new pipe. I have torn it apart 4 times and I still have a leak in the same spot. I am tightening each port on the manifold in an X pattern and both of them pretty evenly. It is really really hard to get the inner,upper most bolts tigthened. I can't get a socket on there so I have to use a normal open end wrench.
1st time bolts not tight enough, bad gasket
2nd time still bad gasket but I realized it this time
3rd time I was dumb and did not put the washers on 2 of the bolts, worst 2
4th time with new gasket, bolts put in right. small leak in the same spot.....
Should I use a gasket sealer? on my gasket, It looks great compared to the old one.
Could I be torquing to bolts too tight? I am not sure of the torque specs on the aftermarket aluminum manifold?
Here is a picture of the engine and the screwdriver is pointing to where it is leaking.
